I think I screwed up! HELP!
I have a stripped bolt that I have no friggin clue how to get out. It's the top bellhousing bolt on the driver side. The head of the bolt is almost but not completely rounded. Advice desperately needed.
Originally Posted by 01WS6/tamu
Take a 14mm swivel and a 3 ft extension and hammer it on. the 14 is a **** hair smaller than the 9/16. That should get you. Thanks Chris
The bolts are all 13mm. am I missing something?
Originally Posted by performabuilt
that will work use a cheap 6 point socket
If the smaller socket does not work... tear a small piece of paper a lilltle larger than the size of the correct socket. Place it in the socket using a fingertip. The idea is to make the socket fit tighter by shimming it.
I also use engine valve lapping compound inside sockets sometimes, it acts as an abrasive that causes the bolt to bite the socket.
g
g
