Speed Density?
Old 12-04-2006, 07:20 PM
Skelbow's Avatar
Default Speed Density?
Getting ready to buy a 99' LS1 / T56 and tryin to piece other parts together as well.
In the future I plan to Turbo the LS1, so I figure I'll run Speed Density.
I've tried to search button and looked in different places but I can't seem to find much info on SD, what exactly do you have to do?
I plan on using either LS1edit, or HP Tuner to fine tune the motor, as well as a wide band O2.
Old 12-04-2006, 07:32 PM
staringback05's Avatar
if youve never used that software id find someone who has who can give you a few key tips and bits of advice.....i know i use a guy on here who knows his stuff when it comes to the editing software....keeps my more mechanical hands off of a the software aspect ...... "doc" if you can find him he could give you some advice....also have you dropped this question in the diagnostic forum?
Old 12-04-2006, 09:20 PM
2002ws-6's Avatar
lots of info on SD tuning in the PCM section and forced induction, Check the hp tuners sticky in pcm. They tell all about 1 bar sd tune which will work untill you go forced induction then you'll have to go up to 2 bar
