corvette fuel rail covers install
Old 12-06-2006, 01:08 PM
mattster03's Avatar
Default corvette fuel rail covers install
i'm curious to know if there are any modifications needed to attach corvette fuel rail covers to an Fbody car. anyone have a quick answer or link? i appologize because i'm sure it's been answered before, but my searches are timing out on me and i'm trying to sell my set on eBay and got this question. thanks.
Old 12-06-2006, 01:24 PM
lsx24's Avatar
Yes, modifications need to be done to fit over the oil fill and something else if I remember correctly. Compared to stock Corvette ones for fbody they need to be cut.
Hope this helps.
Old 12-06-2006, 02:33 PM
mattster03's Avatar
thanks.... any other information on this subject as in specific cuts?
Old 12-06-2006, 02:54 PM
PontiacFan's Avatar
Yes, if no other modifications are done to the car, there will have to be cuts made to easily install them.
Cut rear passenger side for AIR tube relief.
Cut rear driver side for AIR tube relief.
Cut/drill hole for the oil dipstick.
Cut or slot for the throttle bracket.
If you remove the AIR system from the car, you may not have to cut the back ends.
Make sure you use the 97-98 two slot covers. If you start with the one slot covers, you'll have to cut another matching lsot which isn't easy to do & have it match very well. Yes, the LS1 F-body uses the dual lines, hence the reason for the dual slot covers. (I know, you are selling covers that you already have, but I noted this for future reference, if anyone else reads this later.)
http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
Old 12-06-2006, 07:46 PM
Long Beach's Avatar
Search for parbreak maybe he has the templates that you can buy so they will fit your car. I have them on my car and they fit and look great.
Old 12-06-2006, 07:48 PM
presto_z's Avatar
im waiting on my set from parbreak... ohh i cant wait.. they should be done soon...
Old 12-06-2006, 09:17 PM
mattster03's Avatar
perfect. just what i needed, thanks again guys!
Quick Reply: corvette fuel rail covers install
