Port/Polish New Heads
Old 12-07-2006, 09:01 PM
adillhoff's Avatar
Default Port/Polish New Heads
Just wondering what is the best way to port/polish some new heads. I was going to buy some bare 243 casting heads and do the porting myself. I don't have another $500 to spend on the CNC porting.
I definitely do not want to do anything I am uninformed about. Any insight from you guys?
Old 12-08-2006, 07:41 AM
SHAKER's Avatar
If you are doing the port yourself, stick to smoothing out the surfaces and gasket matching. Avoid the seat area as a slip will cost you a seat repair. Rough surface on the intake for atomization smooth as possible on the exhaust for heat dissipation. If you are going to use a dremel, it will take a long time. Buy a die grinder with appropriate bits. Be sure to where a dust mask as the dust is accumulative and the fibers from cartridge rolls are toxic. If you need any other help or ideas drop me a line. shakerheads@aol.com
Old 12-08-2006, 09:32 AM
LS1Formulation's Avatar
Buy the book "How to modify small block chevy cylinder heads" by David Vizard. It doesn't apply directly to LSX engines but it's been a great source of info for me.
Old 12-08-2006, 10:26 AM
Xtnct00WS6's Avatar
Here's a link to get ya started.
https://ls1tech.com/forums/generation-iii-internal-engine/615609-ls6-heads-where-port.html
