Already have HIDs in headlights...which temp for fogs?
I am currently running a 6500k (slight purple hue) Kaixen HID hi/low kit in the headlights that I am very happy with. I'm simply looking to go to HID's for the foglights and am a bit undecided on which color temp to go with. Should I match the headlight temp or go with a temp to match the white LED's (slightly blue tint) such as the 6k kits? Below is a pic of the current setup.
Thanks
-brian
Thanks
-brian
I think a few different things would look great. A 3000K kit? a 6000K kit? or a 10000K kit. It would set both kits off if they were different, make the car stand out more!!
-Nathan
-Nathan
I would either match the H4 with what you already have or go with a 4500 to 5000k H3 foglight to make it appear more white. I like the purplish color of the H4's maybe use more whitish light so you don't make a mis-match in color between the two setups.
I matched mine, 6000k H4's & 6000k H3's
