Need a tune adding heads?
Old 12-16-2006, 05:11 PM
The Sad's Avatar
Default Need a tune adding heads?
Just a quick question to get your opinions. I am looking to just add heads to my setup, I realize I need a re-tune to get the most out of it, but do I need it just for things to work right?
Thanks, Aaron
Old 12-17-2006, 04:29 AM
ringram's Avatar
If your maf table is good you should be ok. If you are running SD then you will need a retune to ensure fueling under PE is good.
In both cases the stock o2 sensors will take care of part throttle fueling where you spend most of the time.
