!a.i.r.?
Originally Posted by sidewayz28
where can u get the block off plates? off a sponsor?
I bought some block-off plates from a website but I don't think they are a sponsor. And they are too thin so you either have to get a lot shorter bolts than stock, or put the end off of each pipe and use that to act like a spacer and bolt down the plate. So instead of spending like $9 a piece for those, just use some metal and bolt it down..or hell..make it bling bling and put a quarter under there
happen to have any pics of what yours look like just to get an idea? how thick is the sheet metal? i know my EGR block off plates are kinda thick
The pics I posted above you can see the metal plates sticking out. It is maybe 16ga metal??
oh thats a piece from the original AIR tube. and u just have a little piece of metal in the middle of both the pieces.
https://ls1tech.com/forums/showthread.php?t=328977
its really self explanatory.. youll need to buy some kind of plug to plug your LID. which people have bought these..
http://www.caplugs.com/catalog/starp...command=search
ok...so basically after i get it off, i need to get something like efi live? so i can disable it so my check engine light wont come on?! where can i get that?
If the check engine light bothers you...you can try to find someone near buy that has HPTuners for your year car and they might delete the codes for free? Or some shops charge $75 to turn them off.
Or if you plan on getting your car tuned just wait til you do that and have the shop turn everything off.
I was deleting the air and the rubber tube that runs from the left side of the motor to the ride side of the motor directly below that, there is a plastic tube inside a rubber house. This tube runs from the back right valve cover around behind the engine and goes into the intake manny on the left hand side. This tube broke when I was doing the !air...what is this tube????
i cut up a license plate and used them as block off plated worked great for a couple of months then i got off road headers. find an old license plate cheapest way to get a block off plate. also i didnt way the a.i.r but it decreases quite a bit of wait. make sure you take the pump and everything else out. also while your at it if u dont have emission get rid of the egr. it is so simple to do these two mods and it cleans up the engine bay very nicely. if u take the egr out and u have the hole in the intake just use a freezer plug i beleive it is 3/8 but ull prolly have to search that
