Comp Cams 238/240, How Much Head Milling?
Old 12-24-2006, 10:56 AM
bluecamaroz28's Avatar
Default Comp Cams 238/240, How Much Head Milling?
How much is safe to mill 241 heads with Comp Cams 54-448-11:
238/240
.605/.609
112
Is 0.040-0.045 head milling safe enough and how much will be the CR with stock motor and stock head gasket.
Old 12-26-2006, 02:13 PM
TTT. Anyone.
Old 12-26-2006, 02:26 PM
redtail2426's Avatar
i wouldnt mill more then like .015 and use stock gaskets. if you want to mill more you will have to flycut
Old 12-26-2006, 06:38 PM
WS6FirebirdTA00's Avatar
do it right and measure unless you want a good reason to screw your motor up
Old 12-27-2006, 07:18 AM
squealingtires's Avatar
The intake centerline on that cam is at 110 degrees. Doesn't say on the cam either, you'll have to call Comp to verify unless that one is custom ground and you are sure on the specs. I have the same one ready to get installed in my engine.
Old 12-28-2006, 03:16 AM
It's a shelf cam from Comp Cams, not custom.
Old 12-28-2006, 09:22 PM
Yeah, call Comp and they should tell you that that cam has an LSA 112+2 right off the shelf. My cam didn't have it marked on the camshaft either and that's why I was suprised. Good for me since I get a little bump in the DCR of my engine with the advance.
Quick Reply: Comp Cams 238/240, How Much Head Milling?
