Comp Cams 238/240, How Much Head Milling?
How much is safe to mill 241 heads with Comp Cams 54-448-11:
238/240
.605/.609
112
Is 0.040-0.045 head milling safe enough and how much will be the CR with stock motor and stock head gasket.
238/240
.605/.609
112
The intake centerline on that cam is at 110 degrees. Doesn't say on the cam either, you'll have to call Comp to verify unless that one is custom ground and you are sure on the specs. I have the same one ready to get installed in my engine.
Originally Posted by bluecamaroz28
It's a shelf cam from Comp Cams, not custom.
