Pacesetter LTs
Old 12-24-2006, 12:58 PM
juicedls1's Avatar
Default Pacesetter LTs
Hey guys i need some help here, i just installed some pacesetter lts everything went real well (only took 3 hours) and i didnt break anything. I still got to get my true duals ran next week, but my prob is i went for a test drive with open headers and the car seem to be missing and running bad, i pulled the front plugs on the drivers and pass side, the drivers side was solid black and the pass side was clean as could be, threw a misfire code, egr code, and a o2 heater code, but i got race headers so the AIR and EGR was taken off, will this clear up after i get my exhaust on or is something wrong somewhere? Merry Christmas!
Old 12-24-2006, 01:02 PM
NviouSS's Avatar
you're going to need to get the air/egr tuned out or you'll be pulling the same codes over and over. you should be ok once you finish the exhaust up.
Old 12-24-2006, 01:07 PM
juicedls1's Avatar
K thanks for the info, thats what i kinda fiqured, im also getting it tuned in a couple weeks to ,so that should help out alot!
Old 12-24-2006, 01:09 PM
LS1TECH Sponsor
foff667's Avatar
if its throwing a missfire code double check your wiring, plugs, wires, coil pack connections etc...yes it probably will throw some egr codes & maybe some front o2 codes since your running on open headers, but i really shouldnt throw any missfire codes for no obvious reason.
Old 12-24-2006, 01:20 PM
juicedls1's Avatar
Double checked all connections, i put in new plugs and wires during the install, so all that stuff is good, i guess running open headers could make it run real rich but its only effecting the drivers side, could i've messed up an O2 sensor running with open headers?
Old 12-24-2006, 01:46 PM
NviouSS's Avatar
i ran open headers for about 1/2 a day w/o any problems engine wise. only thing that happed was when the car was at a certain rpm it shook real bad causing my ttops to unlock. one actually flew off on my way to getting my y put on.
Old 12-24-2006, 02:16 PM
That's what she said...
TheBlurLS1's Avatar
Check your fuse box under the hood for blown fuses. I blew one and it shut down all the coil packs on the passenger side.
Old 12-24-2006, 03:21 PM
juicedls1's Avatar
K,i already checked them once, but ill check them again just in case. Anything else yall can think of?
Old 04-06-2008, 01:33 PM
95Banshee's Avatar
it shouldn't run rich thats what the 02 ajust is air fuel ratio. the after cat ones are just monitors for the cat.
