What's your max timing in lower rpm's and part throttle on big H/C/90/90 set-ups?
I'm curious to see how much timing some of you are running. I'm attempting to get the best off-the-line throttle response, without harming anything ofcourse
I'm looking at .36 gm/cyl and greater from 1000 rpm's to 2000 rpm's in the various tables. I didn't set my max WOT timing until 2200 rpm's.
I've increased my low-rpm tables from stock by as much as 4* in various places from those ranges.
Too little??
Thanks!
Too little??
Thanks!
Originally Posted by nikon1999
i have much more than 4* over stock, hardly tell i have a cam with over .600 lift
Are you talking about the part-throttle cruising cells or .6 gm/cyl and higher under 2000 rpm's?
