Boost and Auto VE
Old 12-31-2006, 02:30 PM
billyjo's Avatar
Default Boost and Auto VE
What am I doing wrong? I'm already lean in boost and it looks like it's trying to take away more fuel. My AFR @ 135 kPa= or - is 12.70-15.08 which gives it an average of 13.8.
Attached Thumbnails Boost and Auto VE-da2a5d96-bed0-e740-397dc497f24dbeec.jpg   Boost and Auto VE-da2b9822-b103-aba5-b05b5de1ca01ab9c.jpg
Old 12-31-2006, 02:49 PM
TAQuickness's Avatar
I'm having a hard time seeing your map screen shot. One thing I could tell, what that you have one map to cover from 15-215 kPa. It will probably help you to split the VE table into two maps corresponding to your calibration. IIRC, one map will be identical to your VE table (15-105 kPa) and the other to your boost map (105 - 215 kpa).
From the chart view, you're commanding 14.xx AFR under the highlighted region. You should be commanding much richer than that.
Old 12-31-2006, 02:57 PM
billyjo's Avatar
So how do I get it to command a richer AFR when I'm in boost?
Old 12-31-2006, 04:54 PM
Coal Mining Director
onfire's Avatar
TAQuickness id dead on right.
Plus which cos are you using? COS5 has a table that lets you set the target AFR plus you need to set PE to activate at 40kPa and set the rpm vs PE table to 11.5 : 1 just for starters....can lean it up later.
Old 12-31-2006, 05:48 PM
Black02SS's Avatar
I agree 100%. I wouldn't go WOT anymore until you set your commanded AFR/PE to 11.5. That is way to lean for a FI setup. If you need help getting it setup, email me your tune and I'll get you going in the right direction.
Old 12-31-2006, 10:50 PM
billyjo's Avatar
Chad,
email sent
Thanks,
Bill
Old 01-01-2007, 07:37 AM
Black02SS's Avatar
Received the email and made some adjustments. Emailed it back.
Old 01-02-2007, 06:59 AM
billyjo's Avatar
Chad,
What you did made a world of difference, I made some more changes and sent it back to you last night, let me know what you think.
Bill
Old 01-02-2007, 08:01 AM
onfire's Avatar
Chad knows what he's doing PLUS he's great to work with.
