8.5 all the way around too small?
Kleeborp the Moderator™
Originally Posted by 98Camarod
I thought the first number was how tall the tire was and the second was how wide it was? The rims are 17''x8.5''.
275/40/17
The first number is the tread width (in millimeters if I'm not mistaken), the second number is related to the sidewall height. It is not a direct measurement though...it is based on the tread width. For example, I run a 275/35/18 tire up front, and its outer diameter is about 25.6" or so. My rear tires are a 295/35/18, and their outer diameter is about 26.1". The last number, obviously, is the rim diameter it is designed to fit.
I'm looking for 2 rims that size. I have thin spoke c5's on my GTA, with 10.5's on the back, and 9.5's on the front. the 9.5's are just to wide. Maybe we can work something out. the 9.5's have 245's on them, and it just doesnt look right, but i cant really go any larger, due to rubbing issues.
please let me know if you're interested, or atleast where i may be able to find more, because i cant find any that narrow.
Where did you find 17x9.5 c5 y2k rims? I didnt know they made these, I would put 17x9.5 all around if I can find them.
I bought the rims for 335 with shipping brand new. They should be arriving within a week. I'm going to be putting 255 50 17 because the tires are free. I will throw on a bit bigger tire when the funds allow, probably 555r 265 40 17. I throw some pics up when this all comes together. Hopefully it will be sooner than I think.
Originally Posted by MeentSS02
Personally, I like the look of wide wheels, but those won't be bad. As for tires sizes, for example:
275/40/17
275/40/17
mostly correct, the second number is related to sidewall height...it is the percentage of the tread width that the sidewall is tall...
example: 275/40/17...
275 = tread width in millimeters
40 = 40% of 275 millimeters = sidewall height
17 = rim size
-cam
