shift point solenoid malfunction please help!!!!
Old 01-05-2007, 04:43 PM
97'4mula's Avatar
Default shift point solenoid malfunction please help!!!!
i am wondering where to get one and where they are at on the tranny and how ez it is to fix. being stuck in 2and3rd is kicking my ***. so please help so i can get my car back on the road.
Old 01-05-2007, 05:04 PM
LS1Tech Sponsor
performabuilt's Avatar
There is nothing called a shift point solenoid , So question what is the number of the code you got to make that determination .
thanks
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-05-2007, 05:49 PM
97'4mula's Avatar
sorry bout that it was P0785
Old 01-05-2007, 07:15 PM
LS1Tech Sponsor
you need to replace the 3-2 shift solenoid and most likley you will be all fixed
__________________
Call 888-744-6542
Old 01-05-2007, 07:40 PM
97'4mula's Avatar
is that hard to fix and where can i get the part
Old 01-05-2007, 07:48 PM
LS1Tech Sponsor
well if your wanting to fix it this weekend you better find a GM dealer open in the morning
cause they will probably the only ones to have it , And its actually easy but you will have to remove the pan
__________________
Call 888-744-6542
Old 01-05-2007, 08:04 PM
97'4mula's Avatar
thank s for the help
Old 01-05-2007, 08:14 PM
LS1Tech Sponsor
not a problem
__________________
Call 888-744-6542
Old 01-08-2007, 10:19 AM
OWENMUSTANG's Avatar
I just changed both. very messy in the driveway but, easy.
replace both soleniod's while your in there..
Old 01-08-2007, 12:21 PM
LS1Tech Sponsor
Sounds like you changed the shift solenoids , He needs to change the 3-2 downshift solenoid
__________________
Call 888-744-6542
Old 01-08-2007, 08:35 PM
DevonsZ's Avatar
What would the 3-2 downshift soleniod have to do with the loss of 1st and 4th gears? I don't understand that and ask because my car has only used 2nd & 3rd gears at times and would also not lock-up in 3rd.
Old 01-08-2007, 08:47 PM
LS1Tech Sponsor
the diagnosis was based on the fault code he gave , which was for a 3-2 solenoid .
devon what code do you have ?
__________________
Call 888-744-6542
