i cant figure out what it is...
Old 01-07-2007, 03:36 AM
andypz28's Avatar
Default i cant figure out what it is...
my clutch has been making some weird noises, when i engage the clutch it makes some kind of weird noise, almost like a grinding noise at times. when i shift it also sounds like it whines. this is the stock clutch still and i have thrown some nitrous passes at it earlier this year, but not often.
any idea on what it could be?
Old 01-07-2007, 04:26 AM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Sounds like the throwout bearing. How many miles on the car?
Old 01-07-2007, 05:19 PM
andypz28's Avatar
the car has around 45K miles
should i replace the throwout bearing only? or should i wait for the money to get a new setup?
Old 01-07-2007, 09:03 PM
P Mack's Avatar
My car made a "rock tumbler" noise when I would let off off the clutch in neutral. It turned out to be a nick in the input shaft bearing when I got my tranny rebuilt. It also made a different grinding noise when I would press the clutch in sometimes at higher rpms. I thought that noise was the throwout bearing, but it turned out to be the pilot bearing falling apart.
The whining you hear when you shift could just be the synchros. Do you hear it when you're putting force on the shifter to get it in the next gear, or does it correspond to the clutch movement?
Old 01-07-2007, 11:10 PM
andypz28's Avatar
it whines more at higher rpms, i dont think its the synchros.
it shifts perfectly fine except for the noise when i engage/disengage the clutch
Old 01-08-2007, 08:02 PM
2000ESES's Avatar
i would think throwout bearing
Old 01-09-2007, 06:00 PM
andypz28's Avatar
would it be ok to thrash on the car at the track?
or should i get this replaced right away?
i was going to wait till i had enough money for a clutch
Quick Reply: i cant figure out what it is...
