Trans cooler spews ATF
It did it once about 3 years ago, check the fittings, looked good, put in some ATF, didnt do it again. Then last week it didn it gain, drove it around all day today and it didnt do it. It looks like its comming from my B&M Trans cooler, any possible ideas?
LS1Tech Administrator
Received 1,493 Likes
So you can't tell if the leak was coming from a line, fitting, or the cooler itself?
I'd say to clean the whole area as best as possibile and look for seepage....
Originally Posted by Vince @ FLT
It could be the clamps on the hose. If this is the case get your self some fuel injection hose clamps. They are about 3 to 4 X the $ but well worth it IMO. I never use the clamps that come with the coolers.
Yep, those worm gear type clamps are trash for this application, IMO. I always use fuel injection clamps as well. Also, that generic hose that B&M provides is not very good. I always get Goodyear hose and use that. Much thicker walls that won't allow a clamp to bottom out.
Thanks for the tip, I'll clean it all up, replace lines and clamps, hopefully end this problem, its an LT1 I have enough issues already with out this one
