Source for weatherpack factory connectors?
I'm doing the wiring on my project and need some junkyard help. I'm using the factory dual electric fans from a 98-02 camaro and aside from the factory fbody wiring harness, any other donor cars use the same connector for the fans? Most fbodie wiring harnesses stay with their engines.
Originally Posted by Zedzag
Thanks guys. I'll try those sources
Or you can buy pre-assembled connectors.....
Links removed by mod. If everyone could refrain from posting links we would appreciate it. The sponsors pay to advertise here and it isn`t fair to them to have other companies get free advertisement.
Find a 02-03 Buick Centry in a junk yard and remove the fan harness from it.
It has the two fan plugs with a 4 wire disconnect at the other end..pull the wiring all the way to the fuse box.
This will be enough wire to run two relays and have a quick disconnect on the fans so you dont have to pull both plugs each time you pull the fans.
This harness with two sealed relays cost me $12.
