busted # 7 ringland minutes after
Old 01-13-2007, 11:06 AM
clone's Avatar
Default busted # 7 ringland minutes after
picked up from rpm and was on way home (rush hour in dallas) was missing @ 2k called rpm was told probabaly fuel pump....a couple minutes later started to rattle, shut down towed home. tore down and found busted ring land on #7 and trashed combustion chamber. now the heads are @fuestal racing getting ported and fixed.also building 396 short block. but for now i have a stock shortblock and heads. i am thinking about putting it in with my cam and procharger til new stuff is done. will this work ok? i am worried that the tune could have been the problem.i had heard alot of good stuff about them. but now i am hearing other stuff too. any suggestions? thanks....
Old 01-13-2007, 11:24 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Ringlands don't just break. Something was obviously not right in your engine. Were the rings gapped properly?
Andrew
Old 01-13-2007, 11:38 AM
clone's Avatar
stock shortblock..............
Old 01-13-2007, 12:06 PM
V6 Bird's Avatar
Proabbly a fuel pump? Come on dude...Where you getting on it on your way home at all? They just dont shell rings at cruising speed. Under boost they do.
Old 01-13-2007, 12:23 PM
Moderator
thechef's Avatar
stock short blocks give up under boost, im sure it didnt happen just cruising, some motors take it longer than others some give up the #7 pretty quick
build a nice stout forged shortbloakc and go enjoy the BOOST
Old 01-13-2007, 01:17 PM
IC....Increasing the ring endgap with stock internals can help it live under boost.
Andrew
Old 01-13-2007, 05:07 PM
clone's Avatar
they said it only produced 4.5 lbs that should not have caused it under light throttle. i am mainly just hoping this block will hold for three or four months.
Old 01-13-2007, 06:06 PM
TINKRD's Avatar
aren't you the one that said you put 90+ bottles of nitrous through this motor with out ever getting it tuned??
Old 01-13-2007, 08:59 PM
clone's Avatar
97 before the pro charger. drove another two months before the charger then had it tuned and was on the way home. when i put heads cam procharger on all the pistons had the same burn pattern/color and no sign of detonation. i am sure the motor was well worn i just want to rule out any other problems.
Old 01-13-2007, 09:57 PM
Got Me SOM's Avatar
keep the boost down to 7 lbs and it will live. loosening the ring gap will not alleviate the problem, it has shitty brittle cast pistons with weak ringlands.
Old 01-14-2007, 06:16 AM
EPP
EPP's Avatar
We don't normally have any problems at 8 psi of boost with an ATI ProCharger. I'd say this engine with all 97 bottles of nitrous having been run through it was probably just waiting to come apart. Bob
Old 01-14-2007, 12:03 PM
clone's Avatar
i was expecting 8 lb out of it but they said it only made 4.5 i checked the blower pully and its a4.5" i am not sure but i thought it was for 4-6 lb????
Old 01-14-2007, 12:46 PM
EPP
EPP's Avatar
A 4.50" pulley should give you a lot more than 4 or 5 pounds of boost, unless you have big cubes and a huge cam. I'd make sure the by pass valve is working correctly, and also look for belt dust on the blower, which would indicate belt slippage. These blower belts need to be really tight. Bob
Old 01-14-2007, 12:58 PM
clone's Avatar
thanks bob i checked the belt before tear down. and the cam is a comp xr 265 hr. not very big by most standards. i was not there when they did the tune but could be a problem with the bov. everything is brand new though. thanks for your help. i wish you guys were closer. we may be driving to conn. this summer how far out of the way would yall be?
Old 01-14-2007, 02:27 PM
99Z28LS1's Avatar
sorry to say but this is the reason why my car isnt making full 7.5psi, for fear of my motor coming apart.
on another note, i hope your build goes better and you run the psi you want
Old 01-14-2007, 02:29 PM
V6 Bird's Avatar
I wouldnt doubt if the tuning had something to do with it...Just my personal opinion. Stock SB or not still shouldnt have blown up "cruising" around to the house like you say.
Quick Reply: busted # 7 ringland minutes after
