HID Kits $199.95 - Only four available!
We have four HID kits for sale. They are all brand new in the box.
I've been running these kits on one of my vehicles for the past couple of weeks and have been very pleased with the quality. The light output compared to my old silverstars is amazing.
The four kits are all 9006 which are the low beams. We have two in 4300K and two in 6000k. The 4300K is a pure white light, the 6000k has a slight blueish color to it.
For the harnesses, we have two that are plug and play, and two of them come with a relay harness. The relay harness draws power straight from the battery instead of relying on the thin stock wires for power. The relay harness gets more power to the ballast, but the plug and play harnesses are a bit quicker to install.
$199.95 shipped for the kits, your choice of plug and play or a relay harness.
Originally Posted by Tim @ EAD Performance
These are the bulbs, ballast, and wiring that you need. They will fit in any housing that takes a 9006 bulb. These will not work on the Firebird because it uses a sealed beam setup.
Copy & Paste Moderator
Originally Posted by lynx853
well it wont work on a firebird without the h4 conversion
Originally Posted by 01ls1lover
All you have to do is buy the connector and wire it right up to your ride.. Bump for a sweet deal!
These kits include everything you need. You do not need to cut any wires, everything plugs right into the existing wiring.
