General Maintenance & Repairs - Busted header
View Full Version : Busted header
smkeater911
01-17-2007, 06:25 PM
Hey guys I have a 98 Z28 Camaro with long tube Jet Hot headers with an off road y-pipe. The car has been lowered 1 1/2 inches. I was driving the other night and did not see a speed bump and hit my y-pipe on it fairly hard. I've hit many times before but not this hard. While looking over my car the other day I noticed that the flang of my passeger side header was cracked. It cracked just above every bolt on the flang. Its still firmly attached and its not leaking at all. I have the metal gaskets on it. Will this cause any problems if I leave it as is? Everyone knows how expensive and what a pain in the ass longtubes are for the ls1. If it does develop a leak down the road will it cause any problems in my engine immediatly? Thanks for your input.
taintedmeat
01-17-2007, 06:28 PM
Should be fine until someone could weld it for you.
Tainted
01-17-2007, 06:49 PM
id say as long as its not leaking you should be ok. id weld it up like meat said whenever you can though just for safety measures
