Fan Settings
You can lower them if you like. If you haven't changed the thermostat, you might not see the results you desire. The stock settings are generally up there. You can try lowering them 10-20* and see how you like that. If you change the thermostat to say a 160 you could try
Fan 1 on 183 off 179
Fan 2 on 187 off 184
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
See here for some additional advice.
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
