My Build. 3rd Front Mount single turbo GTO in the USA
My Build.OFI Turbo GTO
Prop the first to be complete and running too
As some have been reading my threads I wanted to start a new one with all the stuff up front. I still have to add more pics of the pumps and a few more. I must say I am proud of myself since this is the first GM product I have ever worked on.
I am also looking for Sponsors.
Tuning set in stone Chuck and Steven @ HPE have it covered and a little once everything is going.
Specs 2004 GTO
Stage II 6.0L Patriot Performance with all the goodies
Diamond -8.66 cc dish pistons teflon coated skirts and ceramic coated tops Lunati pro mod rods 6.125 length
Stock crank polished
federal mogoul berings
Diamond file to fit rings
Victor JR EFI Intake
Aaron Alum Elbow
Tex ExoSkel Dual Cltuch setup
Nasty Performance Stage 3 Street kit
Custom (2) 340's in stock GTO bucket with return
Mototron 60# injectors
Banhee Gauge Pod
Dynojet Wideband Commander
Eboost2
Sport Comp Eletric fuel pressure gauge
Sport Comp Eletric Oil pressure gauge
OFI Turbo Kit with T76 Qtrim
Pics
Nasty Stage III Fuel System.Motoron 60lbs Injectors
Motor and inake
Ripping parts and rebuilding new motor with them.
Old Motor
New motor rebuilding it back.
You would be surprised at how much the rack the protects the tank, bolts and brackets weigh. I am removing them
Specs 2004 GTO
Aaron Alum Elbow
Banhee Gauge Pod
Eboost2
Pics
Motor and inake
Old Motor
Originally Posted by Smearin
uhh.. Im confused... Are you giving props to yourself?
The intake and rails was I think $379 or 399 shipped to my door
Updated info
Ok tonight I installed the headers... I have to get a tap for 2 bolt holes. There not messed up but need to be cleaned out plus i am ****......
Cross over tube you will have to lift the motor to get it to slide in. On the 2004 the rack lines will need to be rebent cause the will not let the cross over tube connect. I am going to try to rebend it if I can not do that then I am going to get (2) male 90 degree elbows and use 6an line. This is only for the 2004's. Anyways headers fit
Plus on both side the headers have alot of clearence. Pulling them in Joel left alot of room I will get pics as I go
Originally Posted by Slowhawk
Very nice work.
I'm aliitle confused about the title? We tuned 2 front mount turbo GTO's last year
Andrew
Very nice work.
Looks like a killer setup, that's a crazy *** octopus ya have there Good luck getting all of that **** in there, keep us updated.
