Custom bore size Cometic head gaskets
Old 01-19-2007, 01:49 PM
thehammer69's Avatar
Default Custom bore size Cometic head gaskets
Looking for opinions here...
The standard Bore opening size for Cometic MLS LS1/LS6 head gaskets is 3.910". The physical cylinder bore size by specification is 3.898". What is considered the safest minimum gasket opening size for the cylinder bore? I think I have heard of 3.903's. Can it even go tighter?
And yes, i realize chasing the tightest gasket opening to bore size is probably a waste of time, none the less, let's entertain this idea.
Hammer
Old 01-19-2007, 01:51 PM
brad8266's Avatar
call cometic and ask about it, maybe they can hook it up somehow.
Old 01-19-2007, 01:56 PM
I was planning on to...I just wanted to see what has actually been known around here to succesfully work before I did.
Hammer
Old 01-19-2007, 05:07 PM
JPH
JPH's Avatar
Hammer
you must be really trying to squeeze all the compression out of this thing. i would use 3.910 and call it a day, .007 won't change enough to even notice. cometic will cut you anything you want.
Old 01-19-2007, 05:17 PM
Just trying to maximize quench without going under .040" gasket thickness.
Hammer
