Alternator
Alternator
So I replaced alternator 2 months ago with Duralast (refurbished) from Autozone and then changed the battery last week with a Duralast from Autozone.
Anyway, I was driving last night and the battery slowly discharged and was not recharged. When i touched the gas, the charge still didn't increase. This would suggest to me that there is a faulty wire / loose connection somewhere. I have not had a chance to get under the car and look bc it is still raining.
Any other ideas as to why it would seem like the alternator is not even there?
I remember your post from a few days ago - if the wiring looks good and worked for two months probably the alternator. As I said earlier, buddy of mine got rid of his problem with a new GM unit vs. reman parts store one.
LS1Tech Administrator
Received 1,793 Likes
If you are working with an autozone rebuilt alternator, that very well may be your problem. I won't even consider the chain parts stores rebuilds anymore. I go straight to GM, those work much better.
is there an easy way to access the alternator? When i took the last one out, i was manoevering it towards the back of the car (through those hydraulic lines... fuel lines?). It was a total pain in the ***.
And why can't the alternator be on top of the engine bay?
EDIT: thanks for the replies. I checked the red wire yesterday briefly and it's not completely disconnected, but it could be bad inside the connector, i'll try tomorrow. Hopefully the weather improves
