valve spring color?
Old 01-19-2007, 07:57 PM
TA1972's Avatar
Default valve spring color?
Hi, I just bought a set of brand new 243 heads and the springs that came with the heads are blue striped. Can anyone tell me if these are ls6 springs? And also what the lift are?
Old 01-19-2007, 08:20 PM
SSTYCOON's Avatar
I'm thinking those are the older 01 Springs, good to 525 lift. The yellow LS6 springs are 02-04 good to 570lift
Old 01-19-2007, 11:57 PM
Long Beach's Avatar
I have some comp 918's and they come with a blue stripe. But i have heard that the older ls1 springs are blue striped.
Old 01-20-2007, 12:04 AM
LS1>girlfriend's Avatar
i would call whoever you bought them from and if they dont know or sound like they are even a little unsure i would buy new springs. nothing like breaking a spring and having a piston slam into a valve
Old 01-20-2007, 06:39 AM
PREDATOR-Z's Avatar
those are 01 LS6 springs: max lift .540
seat pressure: 90 @ 1.800
Old 01-20-2007, 08:07 AM
vettenuts's Avatar
If the heads are brand new, why would they have 6 year old springs? Something doesn't make sense here.
Old 01-20-2007, 08:37 AM
PREDATOR-Z's Avatar
Old stock, but if they are true LS6, the benefit is the lightweight valves.
Old 01-20-2007, 11:18 AM
vettenuts's Avatar
Not if they are 01's, the valves didn't get introduced until 02.
Old 01-20-2007, 11:26 AM
2xLS1's Avatar
01 LS6 springs were solid blue, not blue stripped.
Old 01-20-2007, 11:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
So these must be 918's.
Old 01-20-2007, 12:55 PM
PREDATOR-Z's Avatar
yeap, you're right, but what if they are 02-04 LS6 heads with either 918's or 01 springs??
Hmmm
Perhaps a couple of pics of top side and underside?
If they have orangish/redish valve base then they are LS2.
Old 01-20-2007, 02:49 PM
vettenuts's Avatar
I guess that's why I am thinking something doesn't seem correct here.
Old 01-20-2007, 02:59 PM
blkbird's Avatar
Pics are necessary in this case
Old 02-26-2007, 09:25 PM
12secSS's Avatar
Here is a picture of the valve springs in question, I am thinking early LS6 (2001). They are 2.125 uninstalled height. No other markings what so ever.
Old 02-26-2007, 09:57 PM
mr2guru's Avatar
Nope... those came from an LS2 243 head. Non-sodium valves, etc...
Those came on complete NIB LS2 heads I've received before. They may be the same spec as '01 LS6 springs though. I don't know. I've got them laying around somewhere (the springs new) I guess I could check them real quick.
Old 02-26-2007, 10:29 PM
GR33N GoblinM6's Avatar
i thought the 03+ LS6 springs were orange striped and were good to .580?? is this wrong?
Old 02-27-2007, 06:25 AM
vettenuts's Avatar
I just bought a set of LS6 valve springs new to rebuild my stock 241 heads, they are solid yellow as they came from GM. This were bought about a month ago.
Old 02-27-2007, 08:26 AM
jub jub's Avatar
That's a beefy looking spring. I'm thinking 918.
Old 02-27-2007, 10:58 AM
98camaroLS1M6's Avatar
Does comp make a single spring that is blue striped called 931?
Old 02-27-2007, 12:43 PM
12secSS's Avatar
Never heard of a 931. I know they make the 921 (dual), 913, and 930 springs.
I am going to have a buddy see about checking the spring rate of these springs and compare it with the early LS6 specs and 918 specs. We should be able to find an answer this way.
Quick Reply: valve spring color?
