Timing Chain
Timing Chain
Im looking to instal thunder racings TREX cam and compcams , head set, meaning springs titanium retainers and hardened valve seats. Would it be worth it to install a high flow oil pump and double roller timiugn chain, while im in there. I only plan on instaling ls6 intake, pacetter lts and ory, and slp loud mouth exhaust because when teh car is paid off for i want to send it off to GMR Speed. The only other ting is that ive searched and it seems that the TREX cam fits without having to fly cut the pistons, i just wanted to ask if this is true or not if im using the stock heads for now. Thanx for your comments and info guys.
I'd very very much recommend installing a ported LS6 oil pump and at least an LS2 timing chain while you're at it. And yes, the T-Rex was designed to be a max effort cam with the stock heads without touching anything, so your PtV will be close, but should'nt cause any trouble.
