doing heads/cam need some part numbers
Old 01-20-2007, 05:35 PM
Cchris1109's Avatar
Default doing heads/cam need some part numbers
hey guys im getting ready for a heads/cam swap but does anyone know the Part Numbers for:
Ls2 Timing Chain
LS4 Oil Pump
GM Head/cam gasket and bolt kit
thanks, im trying to search but im not good at it
Old 01-20-2007, 06:32 PM
02sleeperz28's Avatar
well try calling 1-866-571-7733, thats speedinc toll free number, they should have everything in stock you need. good luck
Old 01-20-2007, 07:04 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Also go check SDPC, Thunder Racing, and Texas Speed.
Old 01-20-2007, 07:08 PM
Cchris1109's Avatar
TSP has the kit for 140 but gmpartsdirect have things cheap so i was curious if i could get it for cheaper
i found the LS4 oil pump and ls2 timing chain
Pump: 54 dollars
LS2 timing chain: 27 dollars
i cant find the GM head/cam gasket and bolt kit that TSP offers
Old 01-20-2007, 07:28 PM
2001whiteSS6spd's Avatar
Here's the GM head installation kit
http://www.sdpc2000.com/catalog/2170...o-Firebird.htm
Old 01-20-2007, 09:45 PM
Proud2bSS's Avatar
LS4 oil pump #12571885
