can i put a LT1 t56 onto a LS1 engine?
Hey i have lined up a buy for a t56 tranny out of a 95 camaro, It of course had a LT1 engine. I have an LS1 and i'm trying to get the facts straight whether or not i can just get a LS1 bell housing and bolt it up, thanx!
ah so it's a no go? i need it to be good, if there's any grey area i'm not gonna do it.
I'm being a newbie, but is the input shaft the part that goes into like where the flywheel and such is?
No go!
The input shaft of an LT1 T56 is too short to use with a LS1 bell.
Yes "the input shaft is the part that goes into like where the flywheel and such is"
Originally Posted by avengedws6
cant you change the input shaft and be good to go??
Originally Posted by GR33N GoblinM6
um.. doesnt the LT1 T56 still use the clutch fork and not a hydrolic system?
Yes it does, hence the need to change the front plate along with the input shaft and bell to swap a T56 either way.
Originally Posted by onebad82z
AFAIK you would need to change the input shaft and the front plate on the trans to make it work, along with the LS1 bell.
