V6 4L60E case and bellhousing same as LS1?
Old 01-22-2007, 02:34 PM
seadoo's Avatar
Default V6 4L60E case and bellhousing same as LS1?
is the case and bellhousing of a 4L60E trans from a 99 V6 bolt up to a LS1??
thanks...
Old 01-22-2007, 02:40 PM
LS1Tech Sponsor
performabuilt's Avatar
Well the bell will bolt up but the input shaft and pump are quite different , Using that trans would require at the least swapping the input drum and pump stator.And the units may be otherwise weaker in several ways
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Quick Reply: V6 4L60E case and bellhousing same as LS1?
