408 and alot of horse..
Hi guys. I been doing some research around here and I have asked a similiar question a few times on other boards.
If you were to build a iron block 408 and wanted 500+ to the rear wheels or horse and similar numbers (lets say 475 rwtq) how would you go about it?
I dont want a CRAZY cam. I had the ms4 and I rather not that radical.
thanks.
thanks.
Yeah I hear ya. I think today I am gonna have one built for me. I been saying that for awhile but I think today is the day.
I was just curious what people have DONE to see the horsepower increase. I always like having a second, third, and fourth opinion before I pay 10 grand for something.. ya know?
See my sig. The cam seems to be what most guys are running. The heads are to small. Need the 225s. Mine did 482hp on a low known dyno with 4.10 gears. Not broke in yet.
i will have close to the came setup and should be about the same numbers hopefully higher
iron 402 AFR205s milled to 59 244-248 113+4 cam 1.75 headers 11.66SCR 8.5DCR mamo ported fast 90/90 im hopin with my 9in to hit 500 and 480TQ
If you are looking for big hp #'s then you need to make sure you have heads that will breath good enuff. the motor is only as good as the heads, what good is a big cam if you cant get enuff air into the motor in the first place. I went w/ a 402 w/ a fully ported ls6 head flowing 320 cfm and a custom grind 248/254 112lsa and I am making 560 hp to the wheels, so if you are looking for a lot of hp make sure you get a good set of heads
