Parasitic HP loss from a dual disk clutch or T56rebuilds tranny???
Old 01-26-2007, 09:30 AM
FCar2000TA's Avatar
Default Parasitic HP loss from a dual disk clutch or T56rebuilds tranny???
I did shitgobs of work to my motor, and only got 405RWHP out of it. It should have been 420-430. I have a McLeod Street Twin clutch, and I'm wondering if that could have caused some of the loss.
I also have the $1800 T56 package from T56rebuilds.com. Anything in there cause more loss than stock?
Anyone???
Old 01-26-2007, 09:38 AM
ls1 joe's Avatar
There is no way one of our transmissions lose more HP than stock. There are no parts that can drag inside of it to cause HP loss. The transmissions use stock gears and stock sliders so that can't be what is causing your HP loss. If you can post a dyno graph for us someone might be able to help you on that.
Thanks,
Amber
T56Rebuilds.com
Old 01-26-2007, 09:40 AM
ls1 joe's Avatar
Eric,
Also what all have you done to the car and just out of curiosity how did you come up with 420-430hp?
Thanks,
Amber
Old 01-26-2007, 09:41 AM
FCar2000TA's Avatar
Thanks,
Amber
T56Rebuilds.com
I didn't think so, just wanted to ask to be sure.
Old 01-26-2007, 09:44 AM
ls1 joe's Avatar
I am going to make a guess on this one. I think you have a 224 cam with an LS6 manifold. Stock shortblock, stock heads and stock rear end. That looks like a normal graph for a 224 cam if infact it is that. Our 224 Cam made exactly the same thing with an almost identical graph. I think I even have it around here we can compair it to. Please let me know if I am close.
Thanks,
Amber
Old 01-26-2007, 10:09 AM
KCFormula's Avatar
FWIW my car with a TR224, ASP pulley, LS6 intake and 10bolt only made 381rwhp.
There is no way you will loose more through a rebuilt transmission. Even if you use Syncromesh or some thick fluid like that you would only loose 1hp if that. I'd say you are making pretty good power for stock heads.
Old 01-26-2007, 10:22 AM
FCar2000TA's Avatar
Thanks,
Amber
That's the problem. it's a mid 230's cam, Volant CAI, 85mm MAF, NW 90mm TB, FAST 90mm intake, Kooks 1 7/8 headers, 2 1/2 true duals
Old 01-26-2007, 10:39 AM
ls1 joe's Avatar
Should have made more than that. Who did the tuning? You are correct on the numbers you should have gotten. The graph looks like a smaller cam. Puzzleing.
Amber
Old 01-26-2007, 10:46 AM
FCar2000TA's Avatar
Amber
a local guy did the tuning, he does the tuning for most of the speed shops around phoenix, so he most definately knows what he's doing.
Old 01-26-2007, 10:49 AM
FCar2000TA's Avatar
Amber
I also have a dual disk McLeod clutch, and a stock 10bolt with 4.10 gears. Something with the clutch, driveshaft, or rearend has a harmonic vibration also.
Old 01-26-2007, 11:17 AM
tim99ws6's Avatar
were those corrected numbers? Being in AZ, that might be what is hurthing you there. I'm not sure what part of AZ you're in, but might want to look into that.
Old 01-26-2007, 11:19 AM
FCar2000TA's Avatar
The numbers are corrected.
Old 01-26-2007, 11:33 AM
Restricted User
2001 Pewter WS6's Avatar
Kook's 1 7/8" Headers are too big for that motor...
Old 01-26-2007, 11:46 AM
FCar2000TA's Avatar
I know, but I will one day put a 402 or bigger in, and I wanted headers that will work on that set up also... I don't want to buy headers again.
Old 01-26-2007, 12:01 PM
gnx7's Avatar
Bigger cams need more compression than factory. That is where your missing power is. Mill the heads and get close to 11:1 and you will pick up some power easily. Those primaries are killing some torque also.
Old 01-26-2007, 01:27 PM
FCar2000TA's Avatar
Arizona Power and Sound consistantly sees 420 - 430 RWHP with my exact setup, using their cam.
Old 01-26-2007, 08:01 PM
SSwanner's Avatar
maybe your car just doesn't like you
j/k man. have you did a leakdown test on it?
Old 01-26-2007, 08:09 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Who did the cam install? Custom spec, advance ground in, installed dot-to-dot?
Bring it to the track and see what you run before you get all worried about dyno #s....
EDIT: Nevermind, I see its a ASP cam.
Old 01-27-2007, 05:25 AM
mcamarols1's Avatar
dude dont get all bummed out, look at my numbers in the sig almost like urs
Old 01-29-2007, 07:17 AM
FCar2000TA's Avatar
not an APS cam. It's the same set up that APS uses, but with their cam. The cam is a custom cam by another shop in the Phoenix area.
Quick Reply: Parasitic HP loss from a dual disk clutch or T56rebuilds tranny???
