Oil Change Light Quiestion
Old 01-26-2007, 10:15 AM
tasilver's Avatar
Default Oil Change Light Quiestion
I Have A Change Oil Light That Seems To Turn Everytime I Start My Car. I Just Had The Oil Changed 1000 Miles Ago. Is This Just A Dummy Light To Have The Dealer Service The Car. The Car Is Also Bogging Down Sometimes Around 3000 Rpm And The Oil Presure Gauge Reads High When This Happens. I Own A 1999 Trans Am M6. Thanks For Any Help
Old 01-26-2007, 12:22 PM
DONAIMIAN's Avatar
Stick the key in the ignition and turn to the "run" position but do not start the motor. From there, go wide open on the gas pedal 3 times really quick and it should turn the light off.
The oil light isnt just a dumy light like a lot of people think. It take into consideration water temp, run time, and a bunch of other factors to decide when its time to come on.
Old 01-26-2007, 12:50 PM
NviouSS's Avatar
or you can hold the trip/reset button until it goes away.
Old 01-26-2007, 12:54 PM
tasilver's Avatar
I Will Try This. I Am Glad To Here It Is A Dummy Light. My Oil Pressure Still Sometimes Seems Extremly High And I Notice This When The Car Seems To Bog Down Between 2 And 3000 Rpm. Any Ideas. Thanks
