Sd Tuned/snow Meth Controller (maf)
Alright, car is 3 BAR SD tuned (hptuners) but I wanted to start messing with my meth injection. The Meth injection is controlled by a Snow Performance MAF variable controller. My question is because the car is SD tuned, would I still be able to use the MAF variable controller that uses the varying voltage in the MAF to start and progressively control the meth injection? I didn't know if the MAF still functioned the same way, but the signal was ignored by the PCM. Also, would I need the MAF fully hooked up to use it? Thanks.
