Video of tick, Pushrod?
What do you guys think it is? The car loses power rapidly at 5500. The car was
racing and after it was shut down, and then restarted it made this noise. Hasnt gotten any worse, but its been put up for a few months. I read about the comon pushrod issue, and the possibility of a rocker coming apart. The car is a 99.
Sorry if this is in the wrong section.
Video
Video
I had similar sound, tho not as loud. Was a loose sparkplug. Easy thing to check, with the motor running, hold your hand on each spark plug wire, if you can feel the wire ticking, that's a loose plug. Worth a shot anyhow.
Thats prety loud ,probably internal and not a plug. A plug is real loud from the side, your is loud up top. Pull the valve covers and check everything out.I'd check the plugs 1st though, before you take everything apart. Videos can be deceiving sometimes.
^^ not really, too consistant of a tick, is it louder under a load? I would def check the plugs 1st after listening to it again, reminds me of when i had a loose plug. Again, it is hard to tell from a vid.
Originally Posted by TORCHD 02 TA
my mustang made that same noise. sounds like a rod knock to me
I don't think I would be starting it until I found out what is causing that. I had a slight ticking, above 2K rpm, last fall. When the motor goes back in everything valve train related will be different except the rockers. If I still does it, I guess I will go to a set of Yella Terra's.
i dont have any imput, i would just like to say thank u for the vid, i saw the bracket i took off my intake and now i know where it goes..hahaha, thanks! sorry i cant help
