Ses Light..will This Be An Ongoing Problem??
Old 01-30-2007, 11:43 PM
AxlDrivEsZ28's's Avatar
Default Ses Light..will This Be An Ongoing Problem??
...first off, i did do a search on this subject but couldn't find a thread specific to my mods...i just got my car back yesterday after getting h/c, ls6 intake with egr prov., edelbrock shorties(i live in cali), and a ls1 edit tune.....everything was fine on the 6 mile ride home...took the car out for work this morning though, and about halfway to work(26 miles), my ses light came on. took my car back to the shop after work and they cleared out the code. he said it was an o2 sensor code and that it might be going bad. i was told it would be $80 to change the sensor...but after he cleared the code the ses light stayed off on the ride home....here are my ?'s...
1. what is causing my car to throw the o2 code if i still have my stock cats in
place??..is it the damn shorties causing the ses light to come on??
2. will the replacement of o2 sensors or the clearing of ses codes be a
persistent problem after the mods??
3. is there anything i can do...i.e. warming up the car longer...to prevent the
ses light from coming on??
4. would a wideband o2 sensor be better to use than the stock one i have
now??
i just wanna know what i'm in store for...thanks all...
Old 01-30-2007, 11:48 PM
dpw41285's Avatar
1. dont know need to see what 02 code it threw. doubt its the headers (carb approved)
2. if it is a bad sensor and you replace it then the code should STAY off. if you just clear it then it may or may not come back...randomly
3. not to my knowledge
4. no just use a bosch o2 sensor if that is your problem. wideband is used for tuning/monitory aftermarket software gauges...your ecu wouldnt read it
Old 01-30-2007, 11:59 PM
thx dpw
Old 01-31-2007, 12:16 AM
That's what she said...
TheBlurLS1's Avatar
DPW's post is correct.
You need to tell us the EXACT code the next time it comes on (Ex: P0143). It could be either front, or rear O2's. The rear O2's may give you an SES light because the car's tuning may be sending an air/fuel mixture past the cats that's not within the "acceptable" range for the stock rear O2's.
The only thing the rear O2's do, is make sure the cats are functioning. The easiest thing to do for them is to have your tuner set the PCM to report no error, or throw no codes, for the downstream O2's (rears).
If it's the front O2's throwing codes, and it persists, I suggest swapping them for Bosch 13111 O2 sensors. They are corvette rears, but the only difference they have from our stock fronts is longer wires, and better heaters.
Here's where you can get them cheap as *****.....
http://rep.speedycarparts.com/parts/...gory=C&dp=true
Old 01-31-2007, 12:20 AM
right on blur...will keep u posted...thx again
Old 01-31-2007, 09:37 AM
LILWS6's Avatar
if you just installed the shorties it could be a possible leak causing the light to trip.
Old 01-31-2007, 11:17 PM
what would be the symptoms of a leak though??.....i was driving about 75mph at 2000 rpms this morning and it came on at the same time it did yesterday...ugh!!..it's starting to really **** me off....should i ask the shop to check for a shortie leak b4 i get the o2 sensor changed??....the code it thru yesterday was for one of the front o2's btw......
Old 02-01-2007, 09:47 AM
LILWS6's Avatar
yea there was a guy at work that had jet hot long tubes that cracked up by the head and they were leaking. setting a code you have to ask him exactly what code it is because there are a few o2 codes like voltage to high valtage to low improper cycle and the list goes on.
Old 02-01-2007, 09:56 AM
LS1Formulation's Avatar
When I installed my edelbrock shorties, I had the same problem. Everything was fine before the install, but one of my rear O2's threw a code not long after. Basically, the O2 was operating right at the edge of it's limit and the new headers threw off the A/F ratio enough to cause an SES light. I simply removed the offending sensor, plugged in a new one and problem solved.
Old 02-01-2007, 05:17 PM
dpw41285's Avatar
Originally Posted by AxlDrivEsZ28's
thx dpw
no problem...you get it figured out yet? what is the name of thoose wheels i like them on maros
Old 02-01-2007, 10:17 PM
..naw..not yet...headed to the shop on sat. to get the code cleared and o2 sensor changed and my headers checked......my rims are off a 35th anniversary camaro.....pretty hard to find.....but i got lucky on ebay!....
Old 02-01-2007, 10:20 PM
weird....i had it tuned though after the install and it still thru a code...could it be the tune messing up the a/f ratio??...
Old 02-01-2007, 10:21 PM
Black Sunshine/ 00SS's Avatar
If you get the Bosch, get them @ NAPA, they have a LIFETIME waranty on them. AutoZone has a 1 year waranty. They are less likely to throw a code.
Old 02-01-2007, 10:24 PM
..the guy at the shop said i wouldn't need the bosch o2's cuz i don't have l/t's.......
Old 02-01-2007, 10:32 PM
dpw41285's Avatar
i would double check with your tuner
