predator broken?
Old 01-31-2007, 10:09 PM
4u 2 nv's Avatar
Default predator broken?
i have an old diablo from RWTD that i still use for codes....just got one today and when i plugged in the diablo...nothing happened. key on or off no screen at all on the diablo..any ideas whats up? could it be my DTC hook DTC hook up on the car itself? any help would be great
Old 01-31-2007, 10:22 PM
horist's Avatar
possible it's the DLC (DTC hookup) ... does your cigarette lighter work? If not, they both share the same accessory fuse inside the car... check that fuse
Old 01-31-2007, 11:40 PM
nitroushane's Avatar
Check this first
If that does not work it could very well be the tuner. I had one go bad after less than two months. Good thing was that my tuner shop replaced it for free.
Old 02-01-2007, 07:32 AM
sprayjunkie's Avatar
Yeah, if the tool does not light up when plugged in it is most likely a fuse. Try powering it up in another late model GM to make sure it works.
Old 02-01-2007, 02:19 PM
2001NBMZ28's Avatar
Yep, check your "CIG/ACCY" fuse.
