POS CME's!!
POS CME's!!
i was gettin my cme installed at a local body shop and was supposed to get it back today and they just called me and said that the center connector between the two oval outlets broke during install and they had to have someone fix it and it wont be ready till tomorrow morning! i was all excited to get her back today too....by the way i had the first generation cme tips with only 1 connector between the tips, not the newer one that has two. I told them to reinforce the hell out of it so i won't ever have this problem again! sorry just wanted to rant....
and while im at it...this weather sucks! im in colleyville but im pretty sure it sucks this bad everywhere in dfw and surrounding areas
They're gonna have to find someone that can weld aluminum. Chances are slim the shop that is doing the work has access to one. Most body shops sublet exhaust work out to a Muffler Shop.
yea they were going to have an aircraft welder or something fix it...thats why its not going to be done till tomorrow....and he was going to gusset (sp?) it...i don't even know what that is but its supposed to be very strong after that.....guess we'll see....
so now they get the cme tips put back together and the welder is charging me $120 for the '2 hours' of labor he put into it....am i gettin screwed?? i mean damn im in the wrong business. It seems to me that it should not have taken 2 hours...even if it is aluminum
Originally Posted by the_hunted
I wouldent pay for that since they broke it. You took your car there and had them do something and they couldent finish it.
IMO it's the shops responsibility(SP) to take care of the customer! I think they should have inspected it befor hadn and then quoted you on the install. I also dont think TIG welding take 2hrs. I dont tig but i do know how to weld, and something like that is not 2hrs worth of work.
oh i forgot to mention, the exhaust guy (seperate from the other welder) is charging me $106 to install the CME. I originally had SLP LMII so all he has to do is remove old tips, make (2) 90 degree bends and then weld it up to the new tips. That one seemed like a lot more work and yet its cheaper. And i still don't think it was worth $106!
I know Id have charged $100 just for the labor to cut and fit the bends and weld it all up. Didnt you take the bends to them? ANother thing you have to consider is the old loudmouth is stainless and id bet they arent using but aluminized crushed bent pipe to connect it. Did you not look at the tips before hand? At least mine would have been stainless!!
Originally Posted by V6 Bird
aluminum has to be very clean. I could see 2 shop hours worth of labor on something that took an hour to get clean, weld up and then gusset it. Not to mention maybe fabbing up the gussets. What do you guys expect? Its a SHOP doing this.
Mike, i know im an idiot for not going to you lol. I would have, but as I explained, I wanted to get it all done at once. Now im paying for it...literally!
Let this be a lesson to all of you out there....give your car to mike!
im SUPPOSED to get it back this afternoon...can't wait to see it....except i might not be able to afford the gas for the drive home at this rate!! If you see a guy pushing a NBM camaro with a freshly painted CME in north richland hills chunk up the deuce!
No I did not take the bends to them. They are fabbing up everything.
