tranny issues
Old 02-01-2007, 05:33 PM
D.Raines's Avatar
Default tranny issues
I have a 1998 formula ls1 with an auto transmission. When at WOT I can not manually shift from 1st to 2nd or 2nd to 3rd. If I put it in drive and floor it,it will shift perfectly.I recently burned some gears in the trans and had it rebuilt. I thought rebuilding it might solve this problem but it didn't. Anyone have any ideas on this?
Old 02-01-2007, 05:37 PM
LS1Tech Sponsor
performabuilt's Avatar
well it could be a tuning issue but what do you mean by wont shift ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-01-2007, 07:36 PM
D.Raines's Avatar
when I shift it from 1-2 or if I try to shift it 2-3 it hits the rev limiter no matter how early I shift
Old 02-01-2007, 10:23 PM
LS1Tech Sponsor
There could be some issue with the overun clutch leakage broken piston seal, sounds like you have a pressure leak when its applied since that the only main difference between OD and manually shifting
__________________
Call 888-744-6542
Old 02-03-2007, 01:14 PM
D.Raines's Avatar
Thanks I will look in to that.
