need a lid for a 90mm fast
id like one as close to that size as possible as im going to go to an sd tune and it will be easy to get couplers. plus i just want it . from what ive heard tsp isnt making them anymore, fast toys was supposed to and ive yet to hear and anything, and lg supposdly does and i cant find any pics/ pricing on them. so any ideas?
That's what she said...
If you measure the ID of a regular lid, they are right at 90mm. If you run a coupler and slip it over the lid, you'll have what you're looking for. Remember that the 75mm MAF actually sits inside a normal lid.
The TSP lid was big enough for an 85mm MAF to fit in the same way.
As mentioned the stock/aftermarket lids are fine. My SLP lid has an OD right under 4" so I used a 4" rubber coupler to mate it to a 4" OD aluminized pipe which then connects to my 90mm TB using a 4" rubber hump hose...zero restrictions and you can really hear it sucking air now.
Originally Posted by redtail2426
I think we need to make a sticky that says all lids have a 90mm opening
I have heard of people picking up a measurable amount of power by simply increasing the size of the inlet before the TB but I havnt seen any real world testing.
having a larger opening in front of the throttle body is a good idea,but i dont think its going to help unless you got a stroker or some bigger cubes.I dont see any 346 needed it.I could be wrong but i will wait to see some results before i changed anything.
Originally Posted by Tainted
G2 is gonna be the biggest
Also, my LG lid acually fit tighter on the MAF sensor than my SLP lid did. It was sutch a tight fit I had to sand down the ridge on the flange of the MAF a little to get the LG lid to slip onto it.
