Which rear gear ratio with a T56 in a 408 Stroker???
Old 02-04-2007, 11:15 AM
Restricted User
2001 Pewter WS6's Avatar
Default Which rear gear ratio with a T56 in a 408 Stroker???
I am swapping out my FLT Level 5 4L60e for a T56. What gear ratio would you suggest and why with the mods I have listed in my sig. I currently have 4.10's in my Moser 12bolt but that whine a bit and was going to swap them out anyway. The car is a weekend cruiser and I hit the track a few times a year.
Old 02-04-2007, 01:04 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
4.56's would make it a bit more fun..
Old 02-04-2007, 01:44 PM
Turo's Avatar
...if you have large diameter tires and slicks. If not, it'll just spin like crazy, and spinning isn't much fun.
Old 02-04-2007, 01:46 PM
Restricted User
My choices I was thinking about were 4.11's, 4.30's or 4.56's. I was leaning towards the 4.30's but wasn't sure which would give me the best performance. I run 27" QTP on 15" rims at the track and 275-40-17 MT Drag radials on the street.
Old 02-04-2007, 06:15 PM
1BDHWK's Avatar
My 4.56's, 408 and 28" tires are pretty violent.
Old 02-05-2007, 08:03 AM
Restricted User
So do you wthink the 4.30's will be too much as well???
Old 02-05-2007, 08:58 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If your running juice you will run out of gear multiple guys who can rev past 7k running out of gear in the 1/4, just consider that. Id say 3.90's. if your not planning on any juice or FI, then 4.30's would be a stellar choice
Old 02-05-2007, 10:07 AM
Restricted User
No FI or juice... I was sort of leaning towards the 4.30's as well but since I haven't had a built motor and a T-56 I wanted other peoples opion and views... I didn't want to get something and find out that it didn't work well.
Old 02-05-2007, 10:45 AM
1BDHWK's Avatar
If you are running N/A, 4.30's and a 28" tire will be fine, depending on shift points etc. I have been running mainly 1/8 mile, due to the distance to travel for 1/4 mile. The one time I got to the 1/4, I tapped the rev limiter twice at the top end....but....I think I short shifted that run.
Ultimately, I think 4.30's would be safe for your application.
I plan on running juice, so the 4.56's are WAY too much for me. But a fun as hell on motor.
Quick Reply: Which rear gear ratio with a T56 in a 408 Stroker???
