You think you know what this noise is?
Been having a strange vibration, the car sounds fine at idle but makes a deep vibration, almost like a knock under load. It still makes the same vibration when not in gear and revving it. The vibration gets louder/faster with rpms. Oil pressure is fine, idle is good, no SES lights. I've had one guy say main bearing/rod bearing issues and that it's not bad enough yet to really be able to tell....WTF? And another friend has said "don't worry about it." Unfortunately I don't have the luxury not to worry about it. Anyone have any ideas?
I can still hear it with the clutch in, clutch is 400 miles old, but it made the sound before and after. All mods less than 2 weeks old in list. I'm afraid it is a rod bearing, I'm going to cut the oil filter tomorrow and unplug a coil at a time to get a closer diagnosis.
James
James
Originally Posted by TXsilverado
Haven't cut oil filter yet, but just changed oil, it looks good and no metal shavings, minimal material on the oil plug, again no shavings. Friend's saying it might be a coil/wire.
James
James
Vibration is still there under load, it got better with plugs and wires, but still noticeable...is it possible that a coil is not dead, but "failing?" As in, not giving enough spark? I'm still hoping its not an internal issue....drives okay, oil pressure okay, just has a vibration and slight thumping noise.
James
James
