Throttle body help!
Throttle body help!
I'm in the process of having my car dyno tuned. The engine is an LS1 pullout swapped into a 70 camaro. Apparantly the little hole in the throttle plate has been enlarged and they can't get the idle down below 900RPM.
Does anybody have an extra throttle plate laying around or know where I can get one without buying a complete throttle body?
Thanks,
Chris
Thanks,
Chris
Restricted User
If the shop has a welder they could just tack up the hole and grind it flush, then just re-drill a stock hole which is .165 in. I would help you out but i dont have any spares. Tim
That's what she said...
Restricted User
Originally Posted by TheBlurLS1
That would work, but make sure they know what they're doing. After it's filled/finished, I'd drill the hole in the other side, or at least in some virgin material. You don't want that welded spot falling out and killing your motor.
