9" or Dana 60
no, you cannot use your stock driveshaft. The S60 requires a shaft that is 1.625" shorter. As far as the debate, the 60 is heavier but is more efficient with its pinion closer to the centerline of the ring gear.
Originally Posted by marthastewart
Get a 12 Bolt!!
Naa just messing with ya. Why not a 12, I thought those were suppose to be good? Something bad about them?
Id opt moser or S60. Thers a reason why the 4x4 guys run them with 44in plus inch tires. Plus their cheaper than 9inches. Last quote I had from moser was around 1795$ with spool, 35spline axles blah blah.
Originally Posted by chuckyt1
I've had both - can't go wrong either way. Got a 9 inch right now and love it
Had a S60, got a 9" and no more problems. A lot more gear choices as well. Picked up 0.75 MPH with the 9" over the S60, so much for more hp to turn a 9".
9" is a proven design and it's been around for a while. I have not had any issues with clearance with my 9". The S60 is a custom housing made for strange. I had a very bad experience with my S60 and I am less than impressed with Stranges build quality.
Who puts it together is just as important as who makes it.
I recommend the 9".
My .02
DJ
Originally Posted by Silas2k
is billingsley racing not making their 9" anymore?!?
