ls6 ls2 manifold
Well...if you use the LS2 manifold, you'll need the LS2 throttle body. The LS2s use the 90mm drive by wire throttle body used in the C6 vette, and GTO. They have a square 4 bolt pattern, compared to the triangular 3 bolt pattern found on the LS1/LS6.
