Which Red Tube Loctite
On ls1howto it mentions to get loctite red tube, but i found a medium strenght red tube and a heavy duty red tube. Which one? Tried searching but couldn't find specific answer, oh and sorry for the dumb question.
thanks
thanks
For what application? Where are you using it? Most LocTite thread lockers have a number. The 222 (purple liquid) and 242 (blue liquid) are the most common threadlockers that can still be removed if needed. The two red liquids (262 & 272) are considered "premanent" and will require the use of torch/heat to loosen at a later time (if needed).
