Simple LS1 Edit quetion
I'm not aware of a way to do so through edit ... w/HP Tuners and I believe Live also it's part of the scanner software ... I don't think autotap supports it either... scan only version of EFI live likely does though
well that brings up another question, after I set my new VE Table by driving with my MAF Sensor unplugged, and setting my high octane spark advance values to my low octane spark advance values, how do I copy my LTFT histogram, and “Paste” it into my VE table. The same with my STFT histogram?
OF COURSE ALL THIS USING LS1-EDIT!!!
The help would be very very great, I am honestly a newbie just looking for as much help as possible and you guys are the greatest.
Thanks in advance,
Fil131
Thanks in advance,
Fil131
Thanks in advance,
Fil131
Thanks in advance,
Fil131
take what your average is and multiply your table by that percentage, then fine tune it by going through the logs. You can make your own excel sheets to help out. If you are keeping your MAF I would get the VE table so that LTFT's stay around -5 to -2, then fine tune only the VE WOT cells, then just tune the MAF table which is easy. The car runs almost entirely on the MAF anyway so I would just get the VE table in the -5 to -2 ballpark and get the WOT VE cells right.
