LS1 Coil Packs???
LS1 Coil Packs???
I have 98 LS1 and im replacing the heads with 241 castings . I have the valve covers for the swap but I have 2 questions. Thanks Guys for you input.
Will 98 Coils fit 99-up coil brackets?
Where can I get brackets or a part number?
Yes the 98 coils will bolt onto the 99+ brackets.
I bought my brackets from SDPC, theyre a sponsor, Im sure.
I had to tap the mount holes in the brackets to accept the bolts that hold the actual coils onto the bracket, it works great.
does the 98 harness plug into each coil individually or will it plug into that central plug like the latter years?
Just wondering b/c I'm starting a project using a 98 harness and need to find coils
thx
thx
thx
thx
The coils individually plug into one harness that has a single plug that plugs into the main harness.... if that makes sense
