My car Shakes bad
Old 02-16-2007, 03:28 PM
02SSofdeath's Avatar
Default My car Shakes bad
when i slow down to a complete stop my car shakes really bad it also chugs like a steam train but all these problems go away at speed on highway but still has that chug sound when i get on it to pass. if anyone as an ideas on what to do i would appericate it
Old 02-16-2007, 03:31 PM
torlak_t's Avatar
might it be your rotors_?
Old 02-16-2007, 03:35 PM
no cause it does it at a dead stop and i have had warped rotors this is way different thanks for the idea though
Old 02-16-2007, 04:02 PM
brad8266's Avatar
Could be a slight intake vacuum leak. I had the same problem with my ford taurus, it turned out to be a small vacuum leak, just enough to cause a rough idle but drive fine above 1500 rpm's.
Check plugs and wires too.
Old 02-16-2007, 04:04 PM
i also forgot to mention its not throwing any codes and fuel econemy has droped just a bit not to much
Old 02-16-2007, 11:41 PM
jester177's Avatar
slp maf sensor maybe if that is the brand? mine did that when i first bought it and a little while after until it was tuned.
Old 02-17-2007, 12:02 AM
Intense's Avatar
Rotors or alignment
Old 02-17-2007, 09:21 AM
W8S SS's Avatar
From New_z... possibly motor mounts, kinda the same thing mine is doing, but the motor movement is visible.
