9" to ls1 u-joint part#
From EPP's web site
That's assuming it's a Moser. Not sure about Strange.
-Mike
You will need the following:
- 1350 Conversion U-Joint (Napa Part # 240-0447) pressed onto driveshaft.
- Axle Bearings Pressed on (Any local auto shop can do this usually): They do not come pressed on because you need to swap the brake backing plates from the stock unit to the new unit and then press the bearings on (This swap is a few minute swap).
- Generic 3" muffler clamps to relocate sway bar.
-Mike
