Trans Am headlight proplem. only opens half way
Old 02-18-2007, 12:52 PM
N3V3RL8T's Avatar
Default Trans Am headlight proplem. only opens half way
A few days ago I fixed two grinding headlights on a friend of mines t/a. I did this by raising the lights, removed the bolt and arms, turned the gears 180 degrees and bolted everything back up. I cycled the lights a few times and everything was working properly.
He called me today and said last night that the pass. side lights was only coming up about 2 inches. Still not making any noises, what could cause this??
Old 02-18-2007, 01:50 PM
Jeremiah's Avatar
I would guess the arm that bolts to the motor was installed wrong allowing the travel limmiter to come in contact with something not allowing it to open fully. Turn them on and look to see if its binding on something.
Old 02-18-2007, 04:46 PM
N3V3RL8T's Avatar
All I did was remove one bolt... slide the arm off... turn the gear 180, the put it back together.
